A/C help
black_ej_8
when I turn on my ac my car shakes to much then my ac compressor works blows cold are and then it will make a really loud sound the belts and then the ac compressor will lock up . any help . thanks :cry:
TokyoSkies
Boost Junkie
Mine is starting to do the whole shaking deal. I hate it lol.
It sounds like your AC compressor might be on it's last leg. I never really mess with A/C (usually rip it out to boost :P), but it's a relatively simple system. Make sure the belt isn't too lose, or too tight. Adjust your timing/cam to factory specs, adjust belt to factory specs, maybe spray a SMALL amount of WD-40 into the pulley on your AC compressor, then wipe it clean, and see if that helps. It's likely about to seize, though. Oh, also, check your freyon level.
egibbs1
Also check and make sure you have the proper amount of refigerant oil in the ac compressor... sounds like it just needs to be replaced at this point.
