gantt
OK guys. My clutch recently fell off my compressor. I bought a known good compressor from a friend. I removed the evaporator and cleaned the fins. I replaced the expansion valve also. Also replaced the accumulator/dryer. Took the car back to my job and did a 30 minute vacuum and recharged the system with 1.37 lbs of refrigerant. The only part I had to guess on was the amount of oil. I added 4 ounces but I'm not certain how much oil was already in the compressor. I meant to measure the oil amount before I installed it.
Anyway, the volume if air is great now. Thanks to an unrestricted evaporator. However, my temperature is only going down to around 80 degrees with ambient air temperature of 90. The compressor is cycling on. My high side pressure is 250 psi, low side at 45 psi. Its not cycling on and off. Just stays on. What could be causing my problem? I don't know very much about a/c systems yet. Just trying to get this done on my own. Thanks guys for any help.
