JdmEGTSXTL
So I have a 1995 Civic EX sedan, auto. I have an abs light on. I have checked all my relays and fuses, and all is well. I tried to pull the codes with my scanner through the 3 pin connector but it tells m “this vehicle does not support abs.” When I jump the two pin connector, I get one long flash, then the light goes out and stays off. Idk if that means code 1 but I am not able to find anything on it. If I slam on the brakes, they lock up, no abs activation. Not having any luck finding info on this or how to reset it. Any help would be appreciated.
P.S. brake fluid is full on master cylinder and and module.
Thanks in advance for
