ABS Question
DaLostONE69
So i was reading online somewhere about the specs on a 99 ex and it said that antilock brakes were optional and that four wheel antilock brakes optional . Is there a way to tell if a certain 99 has the anitlock breaks?
Wax Hands
Smell my finger
I have yet to see any Honda Civic before 2001 with ABS. Also ABS only comes in four wheel configuration. I can pretty much guarantee it doesn't have ABS.
stateofjustin
Many older trucks have primitive ABS that is 2 wheel. A cable runs to a proportioning valve and is rigged to the bed. Since trucks are built to carry a load in the back, when they aren't, they brake majorly front heavy. When the bed reaches a certain angle moving upward the cable adjusts the valve to divert pressure rearward so that the rears don't unload and lock. Two wheel mechanical only ABS. Apparently they have a one channel, one sensor system too... didn't know that.
Cars, not so much... four it is.
"General Motors introduced the "Trackmaster" rear-wheel (only) ABS as an option on their Rear-wheel drive Cadillac models in 1971." - Wikipedia, ABS
cobb2819
my 2000 ex sedan has ABS. during startup you should have an ABS light say on for a second or two and then shut off if you have it.
stateofjustin
The way to tell for certain is to pop the hood and locate the ABS valve assembly. If you have one, you have ABS.
A VIN decode might also be able to tell you, but eyes are best.
