Chance EG
Edit: Per discussion on HT, I've decided to just go with the Go Autoworks RR kit. Seems like it would be way less problematic and barely impact power results. If anyone is curious or has a similar issue/concern I'd encourage you to find my topic there (I have the same username)
I'll try to keep this short. Pictures would be very helpful so I can see how fitment works with these.
My goal is to have an AC compatible ram horn that still allows for the use of a radiator shroud/fan on the side of the engine bay (so a "puller" fan, not push).
My original plan was just to use either the Full-Race AC Ramhorn kit or the Go-Autoworks, but I've noticed in a lot of photos (especially of FR), people don't seem to have room for a shroud/fan on their radiator as the compressor housing of the turbo is too close. I'm now also considering the "RR" kit from Go Autoworks as if the ramhorn kits are too tight, I think the RR manifold would provide more space.
Ideally I'd like to use either the FR or GA ramhorn kit along with a GTX3076R and a 3" downpipe. I want to use this with the GA Radiator/Fan/Shroud combo (see http://www.go-autoworks-store.com/12sialraslfa.html and http://www.go-autoworks-store.com/goalrafansh.html)
Basically, I just don't want to have super tight fitment issues with the kit. I don't want to have barely millimeters of space to work with.
If anyone has pictures of these kits installed with a proper radiator/fan/shroud setup I would appreciate it. Especially of the RR kit, as I've hardly seen any photos of that one. RR is currently my backup plan, I'd prefer a ramhorn if possible for better top end.
