If you replace them early enough, yes- but the bearings can end up damaging the "snout" of the a/c shaft, if thats the case then you need to replace the entire compressor. Just need some simple hand tools to replace the bearings, including a snap ring pliers set, and feeler gauges. You also would need to "re-shim it" because the clearance spec would now be different (should be in the kit). I like to use two feeler gauges to get the clearance spec right, because the clutch plate can walk, or "lean" to one side if you shove a feeler gauge on one side. Best to put them on opposing sides.If you want to try and save it and not going to fix it right away, I would recommend removing the a/c drive belt so there is no more wear on the bearings.
