whats a boud rate? the com port is correct. when i unplug the usb side it says a ton of stuff really fast. when i unplug the ems is doesnt do anything.
i was looking up before on the aempower forums and i found out they have problems with it. theres a fix for it but i dont have the files that theyre looking for. i think im f**ked..
your adapter is not compatible with the ems or very crappy. My friend had the same problem. It could be your laptop, your drivers. Update your usb driver and it should work and make sure the driver is compatible with the adapter.
serial > usb, well any adapter for that matter are a pain in the ass, a lot of them just decide not to work with certain things... if you can try a different adapter, or as stated above try updating drivers etc ... or see if you can use another computer ...
