Yes. AEM makes a dry filter.I would recommend just putting the stock intake back on and getting a K&N filter like xplod3r said. Just make sure it's properly cleaned and oiled regularly. Unless they've come out with new filters over the past couple years that don't require oiling.
I know AEM does, I have one. I'm talking about K&N. And thank you for reminding me because my AEM dry flow is like 6 years old and I think I've only cleaned it a couple of times since I got it LOL. I've neglected my car the past several years .Yes. AEM makes a dry filter.
What?my cold air intake sometimes gives my gas pedal some lag because i think its taking in too much air
what exactly is the box in a 96-00 ex si model that is in the passenger fender well with a tube going into the airbox? i would consider that a cold air intake, yes im sure its restrictive but its drawing in air from outside the engine bay. also might car mods saw no results on pod filters with a daihatsu (spelling?) which im sure is not performance oriented so im sure a civic will see no gains also, the op was asking about mpg and performance so i doubt theres any performance to come from a CAI especially without tuning to take advantage of any extra air the car might actually be getting.The technical answer is what JohnS said. Answering your question as to what makes the best mpg and performance, it's the cold air intake. Also like previously stated, the noticeable difference on a D series engine is minimal. Noticeable and existent are different. Although minor, it's there. Arguing the performance per dollar is another debate. Driving the car properly to maximize mpg is the key. If you're driving economically, you won't get the most performance, and vice versa. Since the difference is so minor, most opt to not do anything at all and stay stock.
Mighty car Mods did a filter test and saw no changes, but mighty car mods also did a cold air intake test on a car with a factory cold air intake design and saw no change lol. It was a very dumb comparison test when most vehicles don't come oem equipped with a performance derived factory intake system like the Nissan Skyline. A honda civic draws air from inside the engine bay in stock form, so there is an increase to be found and gains are relative to the engine size that's in question. It's all common sense stuff when you think about it
What?[/Q
Sometimes when im driving at 3000 rpms or lower and i just hold the gas pedal a little for like 5 seconds and then start pressing it, it doesnt give it gas for a second and then jerks my car forward a little bit. idk if its my cold air intake or just something in my engine.
On a truly stock civic, that air box has a plastic tube that drops down and curves right back up with the opening where air is drawn in directly behind the passenger headlight inside the bay.what exactly is the box in a 96-00 ex si model that is in the passenger fender well with a tube going into the airbox? i would consider that a cold air intake, yes im sure its restrictive but its drawing in air from outside the engine bay. also might car mods saw no results on pod filters with a daihatsu (spelling?) which im sure is not performance oriented so im sure a civic will see no gains also, the op was asking about mpg and performance so i doubt theres any performance to come from a CAI especially without tuning to take advantage of any extra air the car might actually be getting.
You mean because you are out of the powerband and flooring it? Not to mention the y7 has no power to begin with. BTW that is bad for your engine.What?[/Q
no i dont floor it i just push it a little more and it does that.You mean because you are out of the powerband and flooring it? Not to mention the y7 has no power to begin with. BTW that is bad for your engine.
