1.) If I figure it out, I'll let you know, fo sho
2.) Gonna put my dusty custom audio fab skills to work and see what I can come up with..
3.) yah, that's kinda what I was thinkin...
I removed the airbag, fought that friggin yellow connector, til I realized how easy it actually was to disconnect..
Then took the column trim off, removed the three screws that retained the SRS clockspring..
Tried to figure out how to unplug the two grey wires from the clockspring.. what an ass.. ended up snipping them back, at different lengths, so to ease in reinstallment, should the need arise..
installed the hub @ 12 o'clock.. (now I know I an off by a spline or two... I'll fix that tonight)
placed the horn ring on the adapter, then the steering wheel, fastened it all together... That's when I realized my horn button wont fit inside the MOMO horn ring...
so took the wheel assy back apart, pulled the horn ring out, and put the wheel back on. I'll figure out the horn issue this weekend...
Results..
PROS: Hmm.. steering (manual rack) feels much more precise.. I like the thickness of the new wheel, as well.. feels more positive..
CONS: I sit far enough back, and the new wheel is smaller in diameter, enough that it partially blocks the outer portions of the gauges.. Yeah, that kinda sucks.
Also, the SRS light is on solid (go figure, huh
) so I'll be rectifying that, as well..
Blinker cancel inop.. I'll try to fix this tomorrow..
