Hook it up to the top one on the cat, it should work if you just tap that wire but if youre signal isnt strong you might need to solder it on there.nkenda said:I have a 1999 EX. I'm trying to install an A/F gauge. Where is the best place to hook up the signal wire from the sensor. First sensor or second one (I have a high flow cat). Is there a web page out there that shows you how to do this? Thanks
