legend1011
I can't find any info anywhere on this and there has to be something small that I am missing here, but this is not working at all. Okay, here is the deal:
I have a blue and green wire which the Alarm states is for unlocking (blue -) and locking (green -) and I have a negative door locking system (as do most honda's I beleive). Right now, the stock deck that was used for keyless entry has been removed and from what I understand it is not needed as I am putting in an aftermarket alarm which will take over these roles.
When I connect the blue wire to the unlock wire it unlocks and holds it locked as if I grounded the alarm wire. When I connect the green wire then nothing happens at all. When I press my Arm and Disarm button on the remote it does not do anything to the door locks (very frustrating). I have the correct unlock and lock wires because I have tested them grounding them both to ground and they lock the doors so I am lost and confused (the green/orange is unlock and the green/white is lock). Please, any ideas? I am going to try connecting the stock radio tommorow and tapping into those wires to see if the deck is actually needed for some reason. If this does not work, then I will be out of ideas.
My alarm install is 50% complete so it could be two things:
1) Something the way the Honda uses the stock deck that I don't know about
2) My alarm isn't getting power for this function and needs another of the 20 or so wires grounded or powered some how.
Thanks for looking
Thanks for looking
