The car revs up to 9800rpm in all the 4 gears. Runs alcohol wich is found in Brazil by the pump on gas stations.
http://media.putfile.com/REVITUP---VTi-18-Aspro-Rasgando-na-Reta
AEM Cold Air Intake
S2000 TBI
Type R Intake Manifold
Hayame Fuel Rail
S-Max Fuel Regulator
Precision 680cc Injectors
Custom Intake Manifold Gasket
OEM Prelude Resistor Box
AEM Cam Pulleys
AEM Under Pulleys
AEM ECU
TODA Timing Belt
JUN Stage 3 Cams
JUN Springs
JUN Retainers
JUN Pistons 11.6 Compression Ratio
JUN Rods
JUN Crank Shaft
JUN Flywheel
JUN Exaust Manifold
JUN Shift Bar Rubbers
Calico Bearings
Cusco LSD
Short Shift
C&R Radiator
Tenzo R Rear Strut Bar
Revolution Cat Back
Hayame Full Suspension
Z10 Traction Bar
Spoon wheels
Toyo T1R 195/50/15
AEM Cold Air Intake
S2000 TBI
Hayame Fuel Rail
AEM Cam Pulleys
AEM Under Pulleys
AEM ECU
TODA Timing Belt
JUN Stage 3 Cams
JUN Springs
JUN Retainers
JUN Rods
JUN Crank Shaft
JUN Flywheel
JUN Exaust Manifold
Calico Bearings
Cusco LSD
Short Shift
C&R Radiator
Revolution Cat Back
Z10 Traction Bar
Spoon wheels
Toyo T1R 195/50/15
