alpine component speaker system
Zoot187
sisco_09 said:
does anyone know how to install a component speaker system[/QUOTE
What exactly did you want to know? Do I presume correctly that you want to set up the car with separate tweeters, midrange, and subs ?
If this is the case, the mids and tweeters go in the front. Tweets work best typically mounted in the dash, but can also go in the doors with the midranges.
I expect you are going to run a channel for each component. Since you don't say what amplification you are using, I don't know if the amps have their own built in crossover networks or you are using a separate crossover unit. If a single 4 channel amp, mount it under one of the front seats with the crossover if possible.
You again don't tell me what you are doing for subs, but most amps for such have the crossovers built in. Obviously you are going to mount the subs on the back. You can put the amp for them under the other seat, or in the back with the subs.
Don't be cheap with your power wires. Minimum 10 gauge stranded, although 8 or 6 is probably nicer. For the distances involved, 12 gauge stranded speaker wire will work just fine.
Hope this helps a bit.]
DaGFTDOne
Car Audio Guru
Once you get that installed let me know how it all sounds I wanna put 6 1/2 Components in my Scion tC all around. I might even do Type R since its not too expensive
sisco_09
I have the alpines type r now they are actually pretty good
sisco_09
ok I have 2 10" kicker subs that are great i have it going to a kenwood amp i just recently brought the kenwood 25th aniversary amp for my speakers the set came with a crossover box but i'm still not sure how i can kum about this
