Alpine Type-S 6x9
Iakona
RaleighBoy
I am about to purchase some Alpine 6x9 speakers (3-way(Alpine SPS-690A))(IF not would getting Alpine Type-R's be just as good / better?). But Crutfield.com says that they wont fit in my car? Do they fit or dont they, and why not? I drive a 98 EX Coupe... Any help will be of use, and also im getting a Alpine MRP-F250 amp to run the 6x9 and Alpine-S Components in the front... will that amp be sufficient? Thanks Guys.
DaGFTDOne
Car Audio Guru
I see ur problem... Crutchfield probably has them selected as your fronts, they will fit in your rear though, 6 1/2 in front and 6x9 in back
Iakona
RaleighBoy
On location it says Rear Deck?....The Type-R's fit but not the Type-S... im perplexed.
DaGFTDOne
Car Audio Guru
no clue, crutchfield is weird, I know they will fit though
cujo613
the type r,s will fit, though I think you will want todo the alpine 4 ch, and not the two ch. You will lose fader control to balance out
Iakona
RaleighBoy
I thought the amp was a 4 channel? MRP-F250 = 40 watts RMS x 4. What should i get if both fit? S or R...
JoePa98
Rollin Stock!
I've been wondering that too. Crutchfield says only certain 6 X 9s fit in the rear. Is there something we are overlooking?
guwakjai010
Dr Tai tai
the type S are great... i have 6.5 in front and 5.25 in back (5th gen) anyway yea i had problems installing mine cuzfor the front... the mounting brackets that came wit it will only bolt on to one screw... i had to duct tape it down then put my speakers on the brackets. and the back didn't evne have mounting brackets... and it didn't reach all the bolts nor did the pattern match... ionno but like i said.. i have 5th gen not 6th but good speakers tho if powered right...
Illegal
New Zealand
type-s will be good. Amped r's are better. R's NEED an amp with no option though. Both styles will fit anything.
hondagod98
the type r's may be too deep - can't remember if they will clear the torsion bars for the trunk lid.... that may be why they list them as not fitting.... i know the type s will fit... if you get the type r's you will NEED an amp - they sound like junk without an amp... deck power is not enough for those - the type s you can run off of deck power but an amp is ALWAYS better.... alpine still makes the most installer un-friendly products out there though...
Machinehead115
Team Four Door
i have the 6.5" type-s in the front, cause the type-r's won't fit in the front, and 6x9" type-r in the rear with no problems... had them for about 3 years now and haven't had any problems whatsoever :mrgreen:
