DoubleZeroCivic
got an 00 ex coupe. where should i run my power cable from the battery? cant really find a place to run it through the firewall. and i don't really feel like drilling a new hole.
so its by the battery or buy the drivers side? there is one i little below the battery but its to high up inside i cant get anything in there.Right below the battery and to the driver side, there will be a rubber grommet that you can pull out and it'll be a hole that leads to the interior of the car.
it's right below and to the right of the battery. all i do is remove the grommet and drill a hold in it and feed it onto the power wire. then when trying to get through the firewall hole you have to push the wire in and down so it clears blower / heater box. it's kind of a pain, but once you see it under under the carpet and behind the firewall pad, it's easy to pull through. then just pop the grommet back into place.so its by the battery or buy the drivers side? there is one i little below the battery but its to high up inside i cant get anything in there.
