amp problems maybe???
Rubixcu7
Not Fittin In...
ok the first time i thought it was my amp now i dunno....
it shows that the amp is getting power but nothing to the subs. last time i changed the rcas and then nothing happened then i got a new amp then it was fxed... then it happened again... is it the amp again? cuz i dont wanna get a new amp if thats the problem...
cujo613
if the same thing has heppened to two different amps.
1. Your power wire is too small and you burned it up.
2. You bridged an impedance load too low for the amps you are buying and you burned them up.
3. You have bad wiring all the way around and you burned them up.
4. You are buying crappy amps and they burned up.
If its your wiring take it to a professional. Saving $60.00 by trying it yourself costs you a lot more money in the long run
ventturei26
Capt. Fuse
what kind of fuse box do you have, i had a tube style fuse box and it seems that every now and then ill have to rebend the terminal mounts inward again. otherwise check your wires
charles_00Civic
CC'S Longest Running Noob
Wire em up right?? Is it getting the signal from the accesory ont he back of your deck?? If it's a big amp maybe 4 gauge wiring will work better over 8? I use for on my p3001. Worth it bro.
Genuine Rolla
Its PETEY PETE, y0!
make sure you're headunit is putting out the signal. i would check the fuses and all the wiring once again.
