i got 2 bazooka 1214.2s and i sold my amp. i want to get the same one but i want to know which of these 2 amps are better. here are the specs of the speakers and then the amps
SPEAKERS:
ELW1214
Power Handling 350 w
Power Handling with Liquid Cooling 450 w
Impedance 4 ohms
Sensitivity 92 dB
Frequency Response 20Hz-1000Hz
Recommended Power 50w - 275w (RMS)
Voice Coil Size 2"
Magnet Weight 40
Sealed Enclosure .93 cu ft
Ported Enclosure 2.0 cu ft
Port Length 15.71 in
Port Diameter 4 in
Mounting Depth 5 5/8 in
Cutout Size 11 1/8 in
Fs 30
Qts 0.36
Qms 4.98
Qes 0.39
Vas 3.10
Xmax 1.12 in. (total xmax)
Re 3.6
Le 1.4
PIONEER AMP
Peak Music Power 760 Watts
Number of Channels 2
Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
Continuous Power (4 ohm) 125W x 2
Continuous Power (2 ohm) 190W x 2
Continuous Power Bridged (4 ohm) 380W x 1
Frequency Response 10Hz ~ 50kHz
Total Harmonic Distortion 0.008%
Signal-to-Noise Ratio 100dB
Dimensions 12" x 2-3/8" x 12-3/4"
Features
Bridgeable
Channel # Capability 1/2/3
PWM Regulated MOSFET Power Supply
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
RCA Inputs 2 Channel
Input Level Control Hi-Volt (200mV ~ 6.5v)
Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
BAZOOKA AMP
Number of ch: 2
Output Stage: MULTIPLE PARALLELLED HIGH CURRENT MOSFETS
Power Supply: Switcher (Mosfet PWM controlled DC to DC)
1 OHM stable stereo 2OHM MONO
Bridgeable & MIXED MODE (3 CH)
Bass Boost
High and low pass filter
DC OFFSET PROTECTION
SHORT CIRCUIT PROTECTION
THERMAL PROTECTION
STATUS INDICATOR
TRI-MODE CAPABLE
BUILT- IN CROSSOVER
REMOTE CONTROL JACK
MAX POWER: 800W
RMS POWER @ 14.4VDC [4 W]: 75W x 2
RMS POWER @ 14.4VDC [2 W]: 110W x 2
RMS POWER @ 14.4VDC [1 W]: 140W x 2
RMS BRIDGED POWER @ 14.4VDC [4 W]: 220W x 1
RMS BRIDGED POWER @ 14.1VDC [2 W]: 280W x 1
FREQUENCY RESPONSE + - 1dB: 20HZ-22KHZ
THD (80K FILTER): 0.10%
BASS BOOST CIRCUIT (FULL, LP): 0-12dB
SIGNAL TO NOISE RATIO: >90 dB
LOW INPUT SENSITIVITY: 200mV - 6V
CROSSOVER TYPE: HP/FUL/ LP
VARIABLE CROSSOVER FREQUENCY: 60-400 HZ
CROSSOVER SLOPE: 18dB/Oct
LOAD IMPEDANCE: 1-8 OHMS
DIMENSIONS: 16.25" L x 19.75" W x 2.25”H
FUSES: 2 x 25 (A)
SPEAKERS:
ELW1214
Impedance 4 ohms
Sensitivity 92 dB
Voice Coil Size 2"
Magnet Weight 40
Port Diameter 4 in
Fs 30
Qts 0.36
Qms 4.98
Qes 0.39
Vas 3.10
Re 3.6
Le 1.4
PIONEER AMP
Features
Bridgeable
BAZOOKA AMP
Number of ch: 2
Bass Boost
THERMAL PROTECTION
STATUS INDICATOR
TRI-MODE CAPABLE
BUILT- IN CROSSOVER
REMOTE CONTROL JACK
MAX POWER: 800W
FUSES: 2 x 25 (A)
