Amp Whine
Vtec97
Hope this isn't a repost, but couldn't find it when I searched. I recently took out my sub and the big amp, and put in a 4 channel amp wired to the 4 speakers. Now I have a high pitch whining sound that raises and lowers with the RPM's. I looked online and read that your not supposed to wire your power next to your RCA's, or any other wires, so I then redid the wiring so that all of the wires don't run together. I've gone through everything over and over again. I've checked all the wires for a stretched wire, or a splice, or a loose wire...nothing. I've tried moving the ground to diffierent spots, and I've tried a couple opther amps, but nothing fixes the problem.
One other thing I read was usuing a ground loop isolator. That's my next resort, but if that doesn't work, I have no idea. Any ideas/suggestions/solutions/ would be helpful. Thanks.
EG_CaSe
ScAre CrOw
check your RCA plugs u might have to pull them apart and tape em up, i hada cheap amp kit and that was the problem, another thing it might be is if one of the wires have a cut and are touching metal.. id disconnect the amp if i was you mine blew up from it,
Red
You Tax Dollars at Work!
Check for what he said. Also, a noise filter might take care of that problem for you.
Bobo_686
Shiny things amuse me
i had an old pyramid amp that did that, i upgraded to an alipne and i didnt have the probmel naymore...but i would reccomended either running an inline noise filter, or maybe try taping or insulating the RCA cables
a96710
How close is your power wire from the battery to your RCA's? If they are too close it'll pick up noise.
CRX_dude
copyright 2006 omgwtflol
also make shure your power wire isnt running along by the speaker wires
Beelzebubba
SubGenius Member
Perhaps upgraded RCA cables would help.
Power supply wire doesn't matter much. Stranded copper is stranded copper but you might be able to isolate the whine with a better quality shielded RCA cable.
Noise filter is going to be easier than running your RCAs again though
