Ztex
Hello,
I've been chasing a problem with our 2000 Civic EX. 1.6L SOHC
First we had intermittent rough running. Some days it ran fine others not so much. Shut off the car and restart usually cured it.
Yesterday no cure.
Went down the list of tests and fixes. Had codes showing CKP/TDC failure, P1359 P1300, P1302, P1303, P1304 and the dreaded P1399.
Started with a plug check. Found number one plug to be damaged and even rusty looking.
Did a compression test...all cylinders were within 5 pounds with no notable leak down.
Changed plus and wires since they had been on the car for a while.
No fix. Now the car would not even start.
I ended up checking distributor parts and found possible troubles So i replaced the distributor.
Now the car runs and the codes cleared. But there seems to be a bit of a stutter every 10 -15 seconds.
The CEL is no longer on...but when I plug in the scanner it stills shows a P1399 code..ugh
I have checked the injectors with the meter and they all seem electrically sound. the car dies if I unplug any one injector....
I am going to check the timing when I can get a light from a buddy.
I'm stumped....Help!
Yesterday no cure.
