Another Overheating thread..... I know
SuperEF
I know this has been talked about before. Ive searched and nobody hasnt encountered the same problem I think.
Anyway 2 days ago my JDM D15 Del Sol temperature passed the halfway mark and it was surly going to the H mark.
Luckily I arrived home just in time. I checked the radiator, hoses and everywhere for leaks. I didnt find anything. No leaks at all and the radiatorwas full. I started the car and waited for it to heat up. The fan didnt kick in so I got a radiatorfan switch and put it on. The fan still didnt start so I jumped the wires and drove around the block with the fan jumped and it still began to overheat. While I was driving I had to turn on the heat so that will lower the temp which it did instantly.
The radiatorand cooling system was flushed a month ago and this just happened to start. I have playing around for at least a few hours to see if it was an electrical fault but the fuses and relays are fine. I don't have a clue what to do next.
So basically my fan isnt working with the new switch installed, the radiatorand the system was flushed out a month ago and I surely cant use the AC
Im out of ideas.
dethseeker90
Install a add on switch. To keep your fan on at all times
itzrivera
something may be stuck/clogged in your coolant hoses?
dethseeker90
flush the cooling system yourself. Pull the radiator. Block off one side and fill it up with water and get it pressurized see if there's anything wrong with it. Also. You radiator could be clogged. So you can look into that. There also may just be air inside your system. Turn it on and open the bleeder valve by the top radiator hose closer to the head. Remove all the air.
bairdandrew77
What brand thermostat did you get? I always stick with oem for that. You're probably fine either way, I just like the extra assurance. Try bleeding the cooling system couple more times. Put on your old fan switch if that worked before
Sent from my SGH-T399 using Tapatalk
