What's up guys?
At times the Civic will randomly stall and not start until it sits for a bit. Today leaving work it started up, idled down and died. Done a lot of reading, searching, and more reading and to no avail still can't figure it out.
Heard relay and pump whirl, tried again and didn't hear the pump prime (could've left the key ON, so it wouldn't have clicked and primed).
CEL goes off.
I tested relay, good.
Checked ignition switch, only my Hanes manual says to check blue/white-blue/white with key OUT, found a diagram online that said KEY IN. Anyways, when I checked for continuity between those 2 wires with key OUT there was none.
New plugs, wires, cap, rotor, coil all done within the last few months... also fuel filter. only problem is a bent coil spring that I straightened out but I'm pretty sure the car did that before I replaced the coil last year too.
Please help.
CEL goes off.
Please help.
