I have some questions about a turbo. Ive found some pretty cheap turbos online, but its just the Turbo itself. What other stuff is needed besides the turbo? I found a Garret T3 for $200.
Originally posted by SeanMc300
*groan* ok....what kind of plans and hp goals do you want? becuase a t3 turbo is waaaay to generic...what trim? a/r?? other things you need are:
fuel management-- i recommend the apexi vafc
colder sparkplugs
larger injectors
tapped oil pan
intercooler
charge pipes
turbo manifold
downpipe
air filter
boost guage, oil pressure, and egt guage
bov
turbo timer
boost controller
a whole shitload of lines
Originally posted by b16asi226
good call, but dont forget pistons, rods, valve springs (at minimum, a whole valve train is better), fuel rail, fuel pump, etc. turbos are pretty easy power, but the up keep cost and getting everything to make it run at even 75% efficiency is reaaallyy expensive.
I agree.....If I were you I would do a little more turbo researchOriginally posted by b16asi226
