this is off of an audi site i am on. i thought it was interesting and was curious if anyone has a setup with this feature.
so... anyone ever heard or seen this kinda thing on a honda? what do you think about it?audiforum said:OMG Turbo lag no more!!
So I finally got a little time today so I went an hooked up and partially tuned the anti-lag thats a feature on the 034efi standalone...WOW I can hit full boost at 2000rpm if I set it there, not only that, its also loud as all hell. Boost makes my exhaust valve open so I have straight 3" exhaust dumping under the car
Basically this is what rally cars use, you go into a corner and instead of lifting off the gas, you hold down the anti-lag button, and the ecu cuts back timing soo much that the car makes no power, but it loads up the motor creating boost. The gas combusts very late in the cycle., once your ready to get on the gas coming out of the corner, you let off the switch and your immediatly at full boost, with normal timing.
I prolly should mention that the egt's get extremly high so its not like I can use this everytime I drive otherwise Id be replacing manifolds and turbo pretty often, but for the fun runs and such, its great. Now i gotta learn how to properly use it
