anyone add more breathers to valve cover??
CacheHX
anyone done this?? i am boosted an i simply can not get oil to quit leaking out from the valve cover gasket whatever i do. can i just add some more ports or something so that it can breath better. would it help?
Ian01ex
Isn't that what a catch can is for??
hybrdthry911
u need to add 2 fittings to the front of your valve cover and run a catch can setup through that. get 2 -12 bungs welded onto it and run it to a catch can setup. and have it return to the back of the block
thats what we do on the b series, on the d series they might put them on the top or back
ryan89crx
Spoolin single cam!
are you pulling pressure from the back of the block as well as the VC?
CacheHX
i have a line from the valve cover and one from the block where the pcv valve used to be. Does it cause it problem running them both in to the same catch can?
Are there any pics of a setup with more breather ports in the valve cover?
