Apexi Turbo Timer Install
edhgreatone
I am trying to get this damn apexi turbo timer installed. They do not make harness for our cars but I have heard that the HKS harness wires up perfectly. I went to the apexi site and they had some wire confusing diagram on how to cut wires to the ECU and what not. But I wanted like a how to or better directions on how to do it. If somebody has any info on this that'd be great.
evan2
Search owns you
you have a 4 wire igntion, and there should be 3 wires for you, not sure if its like the greddy tt but it was red green and blue
i forgot which wires went to what but you just take the piece where the key goes... follow the wires that are soldered on there and then you have to know what wire is what
get a helms
yuo need power, ign and acc
and then you have a ground
there will also prob be a ebrake one which just turns the car off if someone got in the car and tried to drive once you put the ebrake down it cuts the car off
then a speed sensor wire
thatsa greddy tt so im not sure if its the same
you dont have to use the others
just know which wires you have to use its really easy took about 10 mins to cut n splice
edhgreatone
hmmm alright yeah its just so confusing when you open the package its this little turbo timer and then you see like a huge clump of wires and there's no telling which one goes where
