i am looking for a goo p30 ecu blue print. i recieved my apexi turbo timer today and i need a little help installing this. on the timer it has 3 wires and a harness plug. i know the plug goes to the ignition and you need a harness for that, i was thinking if just splicing and doing it that way.
-on the harness, there are 3 wires, blue, green and red. IF i splice does anyone know which wires to splice into?
-for the other 3 wires, they are grey black and white. the grey wire is to the ebrake switch, the black is the groud to the ecu and the white is the o2 sensor to the ecu. - now heres where i need a ecu diagram for a p30 on where to splice the wires for the o2 and ground into the ecu.
-the chart i got was a shitty one and its hard to make out where to splice.
anyone got some info? thanks
