Pioneer GM-D510M 1000 Watt Mono Class D Power Amplifier
Specifications
Peak Music Power 1000 Watts
Number of Channels 1
Load Impedance Capability 2 ~ 8 Ohm (Mono)
Continuous Power (4 ohm) 300W x 1
Continuous Power (2 ohm) 600W x 1
Continuous Power Bridged (4 ohm) N/A
Frequency Response 20 ~ 240Hz
Total Harmonic Distortion 0.03%
Signal-to-Noise Ratio 100dB
Dimensions 10-3/16" x 2-1/16" x 9-13/16"
Features
Channel # Capability 1
Class-D Design
PWM Regulated MOSFET Power Supply
MOSFET Output Section
Screw-Type Speaker Terminals
Balanced Isolator Input Circuit
RCA Inputs Gold 2ch
Input Level Control Hi-Volt (200mV ~ 6.5v)
Built-in Crossover Variable LPF (40~240Hz, -24dB/Oct.)
Bass Level Control -22 ~ +12dB
And this...
Pioneer Premier TS-W2000SPL
Premier® 12" SPL Component Subwoofer
Features
Size 12"
Woofer Cone Material Interlaced Carbon Fiber/Glass Fiber Reinforced
Surround Wide-Roll 3-Layer Fiber Woven Radial with Honeycomb Cloth
Voice Coil Dual 4-Layer, Long Voice Coil (2 x 4ohms)
Voice Coil Bobbin 4-Slit Glass-Imide
Damper (Spider) Y
Top Plate Thick 7/8" (20mm)
Projected Pole Yoke with Vented Pole
Magnet Construction Double Stacked (110oz)
Basket Design Aluminum Die-Cast Rigid Chassis
Gasket 1-Piece Rubber
Wire Terminals Silver Binding Posts
Specifications
Watts MAX. Music Power 2000W
Watts Nominal Power Handling 750W
Frequency Response 18Hz ~ 2,000Hz
Sensitivity 89dB
Ohm Rating DVC (2ohm or 8ohm)
Recommended Enclosure 1.5 Cubic Feet
Accessory Grill UD-G305 Available
Let me know asap...
I'm not too knowledgeable about audio equipment, but I don't care to have the ultimate sound system just something that is quality.
Specifications
Features
Class-D Design
RCA Inputs Gold 2ch
And this...
Features
Size 12"
Damper (Spider) Y
Specifications
Sensitivity 89dB
Let me know asap...
