ok so I finished installing everything into my 2000 Hatch..Converted to manual... One Problem... when I turn the key... the car jerks forward...the gear gauge D4 is Blinking but [N] is Red... please help
ok i had to replace the cylinder piece thats with the fork.... i started bleeding it... the clutch didnt stiff up much and its still jerkin forward.... if a AUTO ECU is in there still will it make it do that? shouldnt considering the 5 speed tranny is in and not a Automatic.... (SPECS: D15B - 95 EX 5Speed Transmission - 2000 P2E Auto ECU - 97 Civic Shift Linkage ) Any suggestions or something... Warranty is up soon on Tranny need to know... Thank You!
Bled it like 20 times... Still not completely stiff... warranty on tranny is up on the 12th so I have to figure somethin out or im screwed! CLUBCIVIC! Your Member is in need of guidance!
Others are tellin me: Too Much Pressure on Clutch could cause it to Stick or I just need a new clutch... When I put it in reverse just now it didnt jerk or crank... Confused...
i did the 5sp swao to my 00 civic ex i put in the 5sp ecu and it fixed flashing lights but now it idles to low were it will shut off until it worms up but then still idle to low i replace the iac but still does the same i have a skunk 2 intake mannifold anybody have any clue what it could b?
