b&m short shifter
got traction
i rock the sohc
so i installed a b&m short shifter in my car and wow, the difference is huge. the only thing that seems wierd is that the position of 2nd 4th and reverse is like dead center. where neutural was with the stock shifter. is this normal??
Allenef
i'm a dumbass.
coops92hatch
u kept up....until 5k rpm
ya it is jus because of the shorter throws. but ya its completely normal. dont worry bout it
exterm8861
is B&M heavier I bought a skunk2 shifter that's heavier than the short shifter I have
The one I have looks like a toy, though it's really tougher than I thought
anyways i got the busshings and the shifter I need to install did you install it yourself give me an idea of how it is and where would the bushings go
I want to DIY but it looks tough since I only get under my car to change the oil.
Liz
c=}:::::::>
Its easy I did. just do a search on google there are how tos i am sure.
coops92hatch
no its pretty easy, i dunno if its different for an EK, but on my EG it was simple. all u do is take off the shift knob, jack the car up and get under there. unbolt the one bolt from the shifter to the shift linkage. unbolt the 2 bolts holding the plate to the shifter stabilizer, then unbolt the shifter stabilizer and let it drop. the shifter should then pull out. next take the rubber boot off the old shifter and grease up the new short shifter and put it inside the boot. reinstall the shifter the same way it came out. but as your reinstalling put in the new bushings 2. the one should b on the shifter side of the stabilizer, the block looking one. the other 2 should b on the tranny side and they jus slide right in each side. those are simple. just make sure u hav enough wd40 to get all the rust off those bolts. after u eventually get them off let them sit in some wd40 while u grease up the new shifter. reinstalling is a breeze. the only hard thing about it is the tight spaces and the rusty bolts. good luck and if u hav ne problems jus ask
got traction
i rock the sohc
the b&m short shifter is hella heavy, and i wanna get the skunk2 10th anniversary shift knob
