B16 A2
fastblacksi
think i am going to go with the turbo .....what all do i need to make my own turbo kit besides the turbo,turbo maniflod,and wastegate....do i need fuel up grades what all do i need ........
Tactics
yes officer, i understand
best turbo is THE SEARCH BUTTON ! (i feel like a record) This topic has been covered.
turbodhb
boosted mine and it has never been better.
1sckcvc
basic turbo set up...
t3 or t25/t3 hybrid turbo internally wastegated
manifold
charge pipes
blow off valve
oil return line
oil feed line
misc. vacuum lines and t's
boost gauge recommended
boost controller if the wastegate is set to like 20 psi
air fuel gauge..not accurate but close enough to tell you if you're gonna go KABOOM or not
for fuel management if you're on a low budget id get
255 lph walbro intank fuel pump
vortech 12:1 fmu (mind you with an fmy i wouldnt recommend boosting over 7 pounds daily...you can squeeze 10 out at the track)
ignition
just get 2 step colder ngk plugs gapped at .030
and....thats it
dont expect to break records or have a reliable car...chances are your rings will go out or youll blow your headgasket or some s**t.
Heavencent
Remember the Thundercats?
manifold
charge pipes
blow off valve
oil return line
oil feed line
ignition
and....thats it
You forgot an intercooler....not necessary (on low boost), BUT VERY RECOMMENDED. Also, you will need a custom made downpipe to lead to your exhaust system (which you might want to upgrade also to more thicker, 3 inch piping.) You can find a great turbo exhaust system in the exhaust section of www.modacar.com
LatinEM2
La Raza #2
get a Full-Race turbo kit....nuff said....=)
Heavencent
Those are mad expensive...maybe he wants to peice it together for that reason.
Heavencent
And you also forgot the most important (and fun) thing of a turbo system: The kickass Blow Off Valve.
Heavencent
oh, nevermind...it's listed there...didnt see it at first :roll:
SeanMc300
professional a*****e
this sort of topic get discussed atleast twice a week, lets just start locking these because they are dumb and pointless.
