B16
AKAP3P3
i have a b16a2 engine but it threw a rod and now i have a b16a but its obd0 what all do i have to do to complete this swap
M.YASEEN.A
AZEEZ'STR
To my knowlege they are the same set ups bro... Str8 swop put the cams from ur a2 into the a motor which will make it run smoother
504scene
Hell do what he said I'm trying to figure out Sumthin on my a3 which cud help u out to n keep it obd 2 lol if any dam body comment!!!!!!!!
M.YASEEN.A
AZEEZ'STR
The series a 123456 are all the same the difference ii with the cams the the throttle itself.... The rest is the same... Reason to telling you put the a2 cam on the a is because the cam degrees is slightly different and would produce more power output to ur motor on a std and healthy way
