will the B16A 92-93 Integra (XSi) motor fit into my 95 dx coupe as a direct bolt in?, or will i need some mounts, if so where can i find them i havent seen them around, not sure how common this swap is, ne info would be great thanks
i know that, at hmotorsonline it come w/ everything i think i will need, it comes w/ the STOCK motor mounts, and im wonderin if it will bolt directly in like a b16 sirII, or will a need a mount kithandlebarsfsr said:you will need- shift linkage, a hydro tranny or hasports cable conversion, the stock engine mounts, axles, and all that stuff.
I had to buy a mount kit seperately, and I had to cut and reweld my shift linkage to fit, about 3 inches too long.blackcivic95 said:i know that, at hmotorsonline it come w/ everything i think i will need, it comes w/ the STOCK motor mounts, and im wonderin if it will bolt directly in like a b16 sirII, or will a need a mount kit
