Murdered_Si
Dropped the oil pan and removed the oil pickup. Numbers 2, 3 and 4 cylinders had very little side to side wiggle. Only cylinder making noise was #2 cause when I pulled the plug and started the motor it didn't make the knock anymore. After inspecting the rod cap journals , rod journals and crankshaft, there isn't any scaring. there was a tad bit of metal in the oil, but it was very very fine. Would it be ok to just put stock bearings back in or would I need to have the crank machined and put oversized bearings in that are thicker?
