b16a2 bolt question
kato1337
hi! i was wondering what are these bolts called? they leak oil because they broke of i was wondering what is the name of them or part number to take to a honda dealer and order these bolts to replace. thanks!
96733
those are called valve cover nuts, but it looks like you also broke the valve cover studs. not too sure but parts vary for dohc and sohc engines
kato1337
any other suggestions? i order some from dealer but no work dont know which one on the diagram to order someone help please?
swapped
brought back to life....i just did this same thing...did you ever find out which one it is....????
12.8:1 Ls/vtec
IT'S OVER NINE THOUSAND!!
They are really easy to find out which ones they are. They are the 12mm bolts with about 1.5 inches of thread coming out of the top. all the other 12mm bolts holding in the cams don't have the threaded tops so get the threaded top ones and you're good.
