Okay so now my car won't start. I drained the coolant, took my intake out for better access. Disconnected the battery. Removed the ground from the thermostat housing. Put the thermostat and housing back on. Attached the ground to the housing. Unplugged the tps sensor and the sensor ontop of the fuel rail (not sure what it is) just to reroute the tangled mess of wires. Filled up the rad, connected the battery, then started the car. After several cranks it started, idled for about 30 seconds and died. And now it just cranks over
And I plugged all sensors back in before I connected the battery
Solving the overheating issue is obviously #1 priority.
Do you have any solid reason to believe the ECT fan switch on the thermostat housing is bad? If not, UNjumper the fan switch and replace the thermostat (OEM = best). Next bleed the cooling
exactly like this:
http://honda-tech.com/showpost.php?p=39830585&postcount=3
If the temp gauge needle rises to the halfway mark, stop the engine and let it cool, and then try again. If this^ solves the overheating, then do the test of the high/surging idle that I mentioned.
Okay so my overheating seems to be fixed. I didn't replace the ect fan switch today, didn't have the proper sized wrench with me. But I got thermostat in, and the coolant flush done, but my thermostat isn't opening (the lower rad hose isn't getting hot)
I'm not running coolant yet, I just did water for now as I forgot to buy antifreeze. I let the car idle for 30 minutes with the fan constantly on, and then 45 minutes with the fan constantly off. The temperature didn't change one bit. I drove home (about a 20 minute drive) with the fan constantly off and still no change in the temp. Any thoughts?
I got my car running, just a bad ground
