cuzzfolk99 said:
yea i know of a couple people running around on basemaps (dumasses) im gonna get the ecu then the car running the str8 to the tuner!!! but you think that my stock ls can hold 10psi daily?? Ive heard of a few people using the vitara pistons in DOHC motors is the possible?? good results??
Vitara pistons are used in SOHC motors. The DOHC bore I believe is 81mm...and the SOHC something like 75mm, around there.
Also, you can just get a obd1 p75...or whatever, im running a p06 or something but once chipped it wont matter. It dosent have to be from him, because once you get it chipped your replacing whatever he did to the ECU anyway.
You wont have any issues running 10psi with a decent tune. Only issue is that boost is addicting, and if your like me, you want more
What manifold are you using, exhaust setup, DP size etc. It all depends on tuner, and your setup. If you have crappy parts and a good tuner, you could be limited and vice versa. Just to give a example im bone stock b18b1 motor, and with my setup i put down 276whp and 237wtrq at 12psi
