B18C wiring
Hayden_Fourroux
So I am about to start piecing everything together that i still need to swap my jdm b18c into my ej8. One thing that ive searched for for hours is the wiring harness. I have a jdm p72 ecu if i buy an engine wiring harness will it plug right into the ecu? Keep in mind this is the first swap I or anyone that i know has done. Any help would be greatly appreciated. Link to the harness below
Buy $160 2001 Acura Integra ENGINE WIRE HARNESS,MT 32110-P75-A03 32110P75A03 93558-1 Sale
Diana Nam
you need to use the harness for your chassis not your motor unless you enjoy sitting there re pinning/ wiring a good harness. you'll need to use vtec harness
Hayden_Fourroux
Ok so will everything just plug and play or am i going have to cut up the harness and splice into connectors that are on the engine already?
Diana Nam
civic harness is direct plug and play all the sensor plugs uses same plugs the non vtec harness has 3wire iacv that you'll need to switch to 2wire one. also fun facts the 6th gen civc harness is all one piece while integra are 2 piece harness
Hayden_Fourroux
OK so i used the stock EX harness and there are 3 or 4 plugs on the trans side of the harness but there isnt anything left on the engine for them to plug into. Is this normal or am i missing something??
