B18C4 bad ignition timing problem
xtp
Hello, i have swapped B18C4 to EK3. Two years it worked well and in winter I put it out and make some repairs like piston rings, valve seals and etc.
Gave it back and engine works that :
http://www.youtube.com/watch?v=BfjmpCT1P60&feature=player_detailpage
Facebook second video : https://www.facebook.com/photo.php?v=10200924390411948&set=o.92036550973&type=2&theater
I tried to change : distributor, map sensor, spark plugs, injectors with ramp, ECU, spark cables, checked timing belt, checked wiring and connectors. Timing on distributor is set exactly how before when it worked.
Pressure in engine is: (cold engine)
12.5 - 13 - 13 - 12.5 (in bar)
181 - 188 - 188 - 181 (in psi)
Sparks are wet from gas. No check engine codes.
Can someone help me what is it?
Thanks
