mikeyisfresh
first and foremost, I want to go ahead and tell you that I'm new to this forum and tuning hondas altogether. quite simply, I'm a noob.
anywho, I've been doing some research on a 2000 Civic Si I plan on getting... and what I've come across is several people stating that the b20 with the b16a2 head is not a good combination because a b16a2 head revs higher than the stock b20 block was made for.
and it just so happens the Civic I'm getting just happens to have that setup... is there any thing you guys recommend doing to the block to keep bad things from happening?
here's the full setup of the car:
2000 Civic Si (b20 block with b16a2 head)
ARP studs
golden eagle conversion kit
hasport billet mounts
AEM fuel rail with pressure regulator
cold air intake
DC 4 into 1 header
stock ECU
will this frankenstein work?
I'd appreciate any help you guys can offer.
ARP studs
cold air intake
DC 4 into 1 header
stock ECU
