best 10psi+ headgasket
CacheHX
i already have a 10+ psi headgasket in right now (not sure of what brand it is) but its leaking oil bad on the front right corner. so i am going to try a new one.
what is the best 10+ psi headgasket??????????
Handlebars
None Taken.
oem honda is pretty damn good, there are lots of people making tons of hp on them.
TiiM iiS l3eAsT
Scamming Piece Of s**t
20 might be pushin it.....i would look into the HKS metal one they have:thumbup:
ryan89crx
Spoolin single cam!
a lot of high hp cars(400hp+) run OEM MLS gaskets. with ARP studs they will work just fine
FRODO
you might have a warped head or a bad stud.
93turbo16
OEM headgasket is all I have every used. They are great, and I have never had a single problem with one on a good amount of boost.
hybrdthry911
oem head gasket 613whp here.
gaskets are not rated in psi in any way shape or form. u might have one that is fairly thick to lower compression.
if your running a d series i would go with a thick cometic. don't reuse your studs get a new set of arp's
sohclubkid
Sick 6/6
OEM or Cometic... and like stated get ARP studs.
but i would have my head checked for warpage if i were you.
Destroy
Used to go cometic but switched to OEM.
Steven.
Formally Green 91
OEM, im goign to run a HKS though
Steven.
Formally Green 91
f**k cometic, on there site says they can make custmom gaskets, any thick ness andy gasket. they lie
they say they dont have the tolling to make one for a D16a1/ZC engine, i offered to send them a brand new OEM gasket for a template, they refused. so f**k them
ryan89crx
Spoolin single cam!
thats what you get for running the bastard child of D series motors
:P
Steven.
Formally Green 91
but still, they shouldt put on there site they can make custom gaskets, if they cant
AMR Engineering
Nothing beats a good copper sprayed OEM gasket. On a perfectly flate surface they will hold basically anything you throw at them. Get some AEBS studs to go with it and your golden.
If you need anything larger than 81.5 contact Golden Eagle and get their overbored OEM gaskets.
siadam
Correcto.
:cool:
