Best or the biggest Intercooler size for a 92 Hatchback?
Boricuanology
Hi everyone, just like the tittle says, I will like to know which is the biggest/best intercooler that will fit my 92 hatchback. If possible can you guys supplied the dimension and if you guys can provided pictures showing your intercooler set up that will be greatttttttttt.
Matt.
the bigger the intercooler for your set up, the less hp you will see. If you go too big, you'll loose power.
This is why they make many different sizes.
BlackHopeDC5
Is Black Again??? :shock:
not entirely true
the amount of boost you are running at decides the size of the intercooler needed
needless to say if he is running 20 lbs of boost its safe to go find a huge ass intercooler
TiiM iiS l3eAsT
Scamming Piece Of s**t
how many pounds are u gonna be running?
Destroy
The bigger you go, the more metal you will need to cut.
Boricuanology
thank you guys for your reply. when I said biggest i ment the biggest that will work the best. I will be using a T3/T04E/B still thinking which turbo to get. I will be running boost high enouth to get me to the 12's, to start on track days, and normal boost level for the street. about the cutting, if it is necessary, I will do it. keep it coming with the reply guys and if you have pictures of your intercooler and if you can provide dimentions that will be awsome!! I have my eyes set on an intercooler from Precision Turbo: good for up to 350hp but still checking around.
WalterRonny
Amante de los EG's
for t3/t04e that i will run .. i will buy one about total size.. 27.5 X 5.5 X 2.5 .. runing about 8spi and so..
deftone
i have a t3/04e and i use a XS Engineering silvia core intercooler... 20 x 11 x 3 core excluding end tanks. it works awsome... even after beating on it on the dyno the endtanks are always cold. turbo95eg6 has one as well i beliieve and im sure hed say the same
DRAGWORKS
I am using a pwr intercooler that is 24x6x3.5 (30.5 in including end tanks). I feel it fits perfectly. I did not have to cut the bumper support at all. My car made 346 whp at 10 psi with this intercooler.
Rand0m
Adamantium Member
the biggest ive seen on EG is probbly this dude from team rice...
Matt.
BlackHope121 said:
not entirely true
thats what I was trying to say!
