Best Place to .
aNDoNX
Gather all the parts I need to piece together a turbo kit. Any websites better than others? Throw me some links. Thanks
xxsenceo89x
aka superman
turbod16.com
http://turbod16.com/viewforum.php?f=7
il make it easy for you.
you need to find a turbo. if it has an internal wastegate, you need to find a mani thqat doesnt have a hole in it and if its externally gated, you need to find a mani with a hole. then you need to find/make a downpipe. then ic piping, an intercooler/blow off valve. (if you want them. there not needed but theyre highly recommended) you then need to get injectors and see how many psi you want to run. the stock honda sensor is good for 10psi. after all that s**t is taken car of you need to find out how your going to tune it. you get an fmu, a hack, chipped or stand alone. i reommended using a chipped ecu and getting it tuned. after all that s**t, you got a turbo civic.
just remember, its gunna cost more then you think. expect the un expected.
