I believe its just dependent on the amount of boost you are running... if you have the thing set too hard, and you have a small turbo on low psi, it might not be enough to open it.2slo4u said:wut is the difference on soft and hard?..i leave mine on hard but never knew the reason..sound?
So I boost 20lbs on a t3 I will still have to run a soft setupBlahman240 said:its not really just a few options, its not Soft, Hard, the Normal... You kind of got to play with it to get it right. But most honda's would be on the softer side.
hell no you wouldnt. i would run that on hard1999CivicEX said:So I boost 20lbs on a t3 I will still have to run a soft setup
Thats what I thought btw hows the intercoolerShiznit said:hell no you wouldnt. i would run that on hard
the intercooler is in immaculate shape. still building the kit, but i dont think i will have a problem with it1999CivicEX said:Thats what I thought btw hows the intercooler
No, to run 20 pounds you would have to have a pretty nicely built engine, I was saying with most kits that people slap on and run with stock internals. If you know how to build an engine, you'd know how a bov works, and you would know how to run it.1999CivicEX said:So I boost 20lbs on a t3 I will still have to run a soft setup
Block is going to get sleeved with a full bottom end build. As far as BOV goes I already an HKS SSQV don't think it even has an adjustment but havn't looked at itBlahman240 said:No, to run 20 pounds you would have to have a pretty nicely built engine, I was saying with most kits that people slap on and run with stock internals. If you know how to build an engine, you'd know how a bov works, and you would know how to run it.
is that WHP or crank HP?Chaos said:170-180 hp....
