blue mountain honda...
thebossmeng
alright so i got a quote for some work does this sound fair.... 390.00 Cnd for this to be done???
Type 4
Replace engine oil* and filter.
Service front and rear brakes.
Rotate tires**, inspect for wear and adjust pressure.
Lubricate all hinges, locks, and latches with multipurpose grease.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect parking brake adjustments.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
Inspect exhaust system.
Inspect fuel lines and connections.
Check all lights.
Inspect the underbody.
Inspect and adjust drive belts.
Replace dust and pollen filter (if applicable).
Replace air cleaner element.
i think it sounds pretty good.... i just want to know if there is anything going wrong with the car...
toneekay
Rubbin on yo booty
Hey, wtf is blue mountain honda?
toneekay
Rubbin on yo booty
That list sounds like your 30k mile service.
Robin...
D-Series Soldier
:what:...
toneekay
Rubbin on yo booty
390 in what currency? Sounds like a lot of money for what you can do yourself...
toneekay
Rubbin on yo booty
Thank you!
*Accepts award*
mahalo
formerly egninesallday
idno what the hell currency your talking about but i can get all that done down the road for 60 us dollars. minus the oil change
toneekay
Rubbin on yo booty
I did my 30k & 60k mile myself... On all my Civics.
JohnS.
BANGARANG
Type 4
Check all lights.
Even if you're not mechanically inclined, you can do almost all of these things yourself.
Engine oil & filter, you'll want to pay someone for.
Brake service, you'll want to pay someone for.
You can lubricate hinges yourself. Go get some white lithium grease for door hinges, hood latch, and your trunk latch. It's messy so I suggest shooting it off into the grass first to test how much comes out depending on how hard you press down on the trigger.
You can inspect everything on your own. Just look for everything out of the ordinary: cracks, rips, leaking, anything bent / distorted from "natural" position, broken stuff, etc. If it's your 30k mile service, it's still a brand new car, so there's a chance you won't see anything wrong. Also, be sure to listen to your car every once in a while when you're driving. Listen for any abnormal noises. This can indicate something is wrong too.
Check fluid levels speaks for itself. On every reservoir, there should be 2 lines, 1 for minimum and 1 for maximum. Just check to make sure they aren't too low.
Check all lights, again, speaks for itself. Just turn every light in the car and and off and check them.
You'll want to check with someone to see if your car has a "dust/pollen filter". Sounds like a cabin filter.
Replacing your air filter, you don't have to do necessarily. Just check it to make sure it's clean and nothing is in between the cracks.
NYGraFFit1
I Tap JdmPrncss
what would that be in american dollar's? cause then it matters, and ditto to you being able to do half of those thing's urself
Szady
D-Series Master
Look at Johnny getting all techincal. :lol:
JohnS.
BANGARANG
Tryin to help a brotha out ;) :lol:.
mahalo
i pay to have this done to a car im going to buy. none of it is hard
thebossmeng
alrigt so i think ill do it myself if you guys say i can.... but now i have a question, was out driving highway speeds an the whole car is vibrating....what would be causing this????
NYGraFFit1
I Tap JdmPrncss
have u changed your tires recently, axels or anything suspension wise?
toneekay
Rubbin on yo booty
Have your wheels rebalanced and aired up to the correct psi. A lot of tire places (chains) do rebalancing for free if you've been a customer before. If this doesn't help then you have a different problem.
