molokai_2008
I have a 1996 Honda civic lx, manual trans. My window motor on the drivers side door works sometimes but not all the time. sometimes it goes down, and when it does i gotta help it to go back up. other times it doesnt respond to me pushing the button at all. i tested the button and it works, i also bench tested the motor on the car battery and it works, im thinking it could be an electrical problem but i have no idea. any ideas???
My rear passenger side window also experiences the same problem but when it goes down it doesnt go up at all with either the main switches or the door switch. when it does decide to work it goes up smoothly. I took the door apart, tested the current going in/out of the switch and its there (the light tester) the motor works fine when i used the battery to test it and the regulator looks fine to me. What could this be???
Any ideas, anything will help...
Thanks
Thanks
