boost leak tester
slowhatch
torque?
Boooo. The site wont load for me and I need to do a boost leak test :(
el_betiyo
me too^^^
.................................to bad I don't have turbo no more=(
good link though
silentdaredevil
Its not slow, its lag
i did something very similar. I was suppose to be on 8 pounds and was only boosting 3. Used this method, Problem solved...
lkailburn
if you want a simpler, cheaper setup than that, just take each charge pipe off one at a time, put a coupler on each end, and duct tape shut the coupler. then in one, poke a small hole in one peice of duct tape and shove in your air compressor and spray away. then spray the welds with soapy water.
Very similar to what was posted, just is a bit cheaper style.
-Luke
