My head gasket is leaking oil just a lil lil lil lil bit and im about to run about 7 to 8 lbs of boost. would it be a bad idea to run boost with that lil leak or can it wait until after i boost?
Wont hurt much, it will probobly make that leak slowly get bigger. Heres something to remember, fix everything to perfect working order before you start doing big mods, and while you at it build the motor to handle it.
probably wont blow the engine just from the head gasket going out...i would watch your oil level though to make sure you have enough oil in the engine....
