a slight bore only lets you put in a new set of pistons. it cleans up the walls for better clearance for the new pistons that you put in. Sleeving totally changes the structure of the cylinder walls. Lets sat When we sleve a B16A block, we start off with a sleeve that is about 80.5mm bore size and we can bore and hone it back to a stock 81mm bore and up to 87mm bore. most turbo setups are kept at 81mm, 81.5mm up to 84mm. All motor bores are about 84mm for street and 85-87 for more hardcore setups.
Sleeving for higher boost is recommended since the sleeves are thicker and can withstand the pressures that the motor goes through at high boost.
Here's an example of a B16 that is sleeved and we put in 81.5mm bore pistons in it.
Sleeved motors like this are what we put in street and even race cars that boost from 15psi-35psi. If you are planning to boost your B18B, its recommended to sleeve the motor. a basic rebuild of pistons and rods without sleeving is good but is only adviesable to about 15psi. you will still have the weak point at the sleeves if you just bore and hone for new pistons. the Sleeved block is a bit more, but does give you that insurance of being able to boost alot more on that motor.
check out the difference in prices between a sleeved block and just a basic Built block on our site. it will be a stage 3 vs a stage 4 block. it shows that sleeving adds another $600-700 to the build up.
