? bout injectors
TurboTravo
i have 98 civic and im buildin a turbo kit for my d. i allready have a turbo its a mitsubishi 13G. i was told i could use injetors from a turbo eclispe that they wil fit. they are 450 cc. is this true?
Ravage70
yes they fit but u might have to use the honda orings on the top of the injectors and u need either to get a resistor box from 88-91 civics or u can get 4 (10 watt 10 ohm) inline resistors from radioshack.
TurboTravo
thanks i appreciate it
evan2
Search owns you
450s are overkill, for a small turbo like that
nothing wrong with going bigger for future set ups, and a afc can control them but i hope you have something to control the fuel with such large injectors compared to stock
evan2
Search owns you
oh yea i have a resistor box i can sell you cheap
evan2
Search owns you
dont matter 25 shipped its yours
Exospeed*com
exospeed.com
450cc is not necesarry for a small mitsu turbo. the most i'd go is some RC 310cc injectors.
evan2
Search owns you
paypal or check dont matter... check will take longer of course
banzai
Exit Speed Garage
I wouldnt say 450 is overkill, it all depends on what you hp goal is. It doesn't really matter if the turbo is small, you can run just as much boost as any other turbo (as much as the wastegate allows).
It just matters about what you want to do with the car...
Exospeed*com
exospeed.com
the reason I say its overkill is that he's using a small Mitsubishi turbo. the efficiency of that turbo can only be pushed to no more than 15psi. what I mean is that at 15psi, its already trying to push so much air into a small turbo, when you can just get a different sized turbo and the same effects will be had with much lower boost.
you have to think of a turbo like a hose. it can only push so much depending on the size of the hose.. so when you have a small garden hose pushing at lets say 50psi versus a firemans hose that is pushing the same 50psi. the firemans hose can push out more volume of water. its the same with air and turbos.
So when someone comes up to you with a turbo civic pushing 18psi on a homemade mitsubishi turbo setup, versus one of our Precision PT67/ T4 turbo at also 18psi. Its possible that the difference on each setup is 200-300hp.
