i finished my turbo install today and im not getting much of a blow off sound. i have the rfl bov. is there a specific vacume line to hook it to or just any one. and when it does blow off it like sputters. any ideas on whats wrong?
x2if it is a real RFL bov then im guessing you arent running enough boost to make the RFL work properly. and where do you have the vacuum line hooked up to?
That is your problem right there. Get rid of that and get one that is not some Chinese junk.its an ebay one.
get a real TurboXS RFL bov and dont put and washers in it so that takes less boost pressure to work properly.yeah. i wanna get one that has the same type of fitting. its not a bolt on one it just slides on.
If you wanted it stiffer you twisted the top down, and to make it softer you just twisted it up.
Would still be just as stiff just not as long.you can also cut the spring thats inside. Cut about a coil off or so
